Regular Contributor I
With IAP175, how can i improve the mesh link bandwidth?
We have a mesh link between two IAP175, with 5ghz, 14 dbi sector antenna. on the mesh point and the mesh portal.
what is attempted is to bridge two ethernet segments using the IAP175 mesh backhaul.  what bandwidth is normally achivable across this setup?
what tweaks can be made on the IAP config to improve the bandwidth across the mesh link?.
Re: With IAP175, how can i improve the mesh link bandwidth?
What distances are you working with, and what speeds are you seeing?
Jerrod Howard
