Jef
Wlan controller errors
The wlan controller logs lists the following errors:
  •  lldp[3860]: <351008> <ERRS> |lldp|  GSM PORT_INFO Lookup failed at Function: lldp_recv for port 26 result 43
  • KERNEL(APNAME@10.11.12.13): RESTARTING ALL TX
Any ideas what causes these?
Useful post? kudos appreciated!
Re: Wlan controller errors
- What version of ArubaOS is this?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Jef
Controller: A7210
AOS: 6.4.2.6
It is a cosmetic error that should have a lower priority.  Typically it is when a client sends a frame that is tagged for a VLAN that does not exist on your controller.
