Frequent Contributor I
Wlan optimization like to seek guidance how many SSID etc
Wlan optimization works should be carried out would like to seek guidance?
Details are as below.
How many essids can be broadcasted or can be used as hiden ssid?
Is there going to have any effect having many profiles on the controllers but not assoicated to any AP-group?
Is there any limit on number VAP's , if have more that is it going effect the performance?
As we have a mix of AP-125 and AP-65 in the environment, disabling HT on radio profile "a" and "G"  will help?
MVP
Re: Wlan optimization like to seek guidance how many SSID etc
There are recommendations for this
Recommended just 2 vaps
Max 3 vaps...
Here are some good reading about SSIDS
http://www.arubanetworks.com/pdf/technology/whitepapers/wp_Virtual-Access-Points.pdf
Here is a table that will give you more visibility regarding this
http://www.revolutionwifi.net/2013/10/ssid-overhead-how-many-wi-fi-ssids-are.html
Cheers
Carlos
Alternetworks Corp
