Woops - Wrong AP-Group
So - while troubleshooting some RAP3's, we found that 5 are in the wrong AP group.  I've done the local-userdb-ap modify, local-userdb-ap del  and clear gap-db commands to remove these RAPs and hopefully start over.  Nothing.
With that said, what is the trick to get a RAP back online if you "woops" on a group/add the RAP to a group that doesn't exisit?  Do you need to do Fact Reset for the output to reflect when doing a            sh ap database long   ?  As of right now I have a FLAG value of   UR-c2G when running the sh ap database long   command.
Your input = greatly appreciated!
Thank you!
Re: Woops - Wrong AP-Group
In case anyone asks -- I forgot to add  - this is a Master to Local relationship, so the DB etc needs to be done on the Master.  Clear gap-db doesn't work on the local.
If the access point appears on the controller, just reprovision it to the right ap-group.  Otherwise, reboot it after you fix the entry in the rap whitelist.
