Zebra wireless printers not getting an IP
We have a lot of these devices in our environment and about two months ago, specific sites started having connectibity and DHCP issues specifically with these printers. We have several models, the QL320, QLN320 and QLN420. All are experiencing the same issues. THe QL320 is an 802.11b devices, the others are capable of 802.11a.
No firmware upgrades, hardware replacements or any other configuration changes have occurred. We use IAP 225 managed by Airwave. IAP are on 6.5.1.5, Airwave is on 8.2.3.1. DHCP is provided by InfoBlox back in the DC. So the DHCP path travels over the WAN and back.
We have tried all manner of tests and such and no matter what we do the problem either remains the same or gets worse. I am going to do a datapath session capture next, and try to get some fresh PCAPs as well.
Has anyone seen this before?
Re: Zebra wireless printers not getting an IP
Are you guys using PSK ?
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
No these are using WEP because of the age of some of these printers
Chris Watson
210-488-6605
Sent from my iPhone
MVP
Sorry, I know this is an old thread. Just curious if you ever found out what was causing this. I have this same issue. Client passes authentication (WPA2-PEAP) and gets assigned the correct VLAN and User Role but does not receive an IP. Even if I statically assigned an IP address, the client cannot be communicated with.
Hello, we have not really found the actual issue. The printer appears to be ignoring the DHCP offer packet. We had Zebra come out do some extensive packet captures. They are stating that our DHCP server is not following the IEEE standard, but I am dubious to say the least since everything else is able to pull an IP with no issue.
If you are able to assign a static IP but it still won't communicate that sounds like there may be a firewall policy or routing issue possibly. Just for the basic checks and balances, is the VLAN tagged all the way to the AP? Are you able to connect to a wired port that has that VLAN assigned and get an IP/route properly?
Most likely a different issue in this case, as WPA2-Enterprise acts differently than WEP preshared key.
If the user is successfully authenticated via PEAP, check the user role to ensure what firewall policy is applied to that user. The controller may be configured to enforce DHCP, which would prevent the static IP address from working.
Charlie Clemmer
Aruba Customer Engineering
MVP
I have double checked the user role and user vlan pushed back from ClearPass and everything is correct. I even set the user role to allow all just to see, and still no dice.
If it connect the device to our Guest network, it gets an IP no problem. If I connect it to a WPA2-PSK hotspot on my smartphone, it can get an IP no problem. It only has an issue when it connects to our WPA2-ENT SSID that it is unable to get an IP address.
I may need to contact the manufacturer to see if they have seen this.
You can enable User debugging for that device:
config t
logging level debug user-debug
Try to Associate
Type "show logging user-debug all" to see if you can get a clue what the device is doing.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
So after looking at the user-debug, it looks like initially everything goes fine, the user gets back the VSA from the ClearPass and the user role and vlan are switched accordingly, but still no IP.
Then after a short period of time the device takes a default IP of 192.168.254.254. The messages that then show up in the user-debug would seem to indicate that the devices falls back into the default VLAN for the controller itself (the vlan we use to manage the controller and AP). Not sure why this is happening.
Here is the user-debug log
Apr 3 15:03:59 :501093:  <NOTI> |AP 18:64:xx:xx:xx:xx@192.168.xx.xx stm|  Auth success: ac:3f:xx:xx:xx:xx: AP 192.168.xx.xx-18:64:xx:xx:xx:xx-18:64:xx:xx:xx:xx
Apr 3 15:03:59 :501095:  <NOTI> |AP 18:64:xx:xx:xx:xx@192.168.xx.xx stm|  Assoc request @ 15:03:59.346482: ac:3f:xx:xx:xx:xx (SN 43): AP 192.168.xx.xx-18:64:xx:xx:xx:xx-18:64:xx:xx:xx:xx
Apr 3 15:03:59 :501100:  <NOTI> |AP 18:64:xx:xx:xx:xx@192.168.xx.xx stm|  Assoc success @ 15:03:59.347243: ac:3f:xx:xx:xx:xx: AP 192.168.xx.xx-18:64:xx:xx:xx:xx-18:64:xx:xx:xx:xx
Apr 3 15:03:59 :501100:  <NOTI> |stm|  Assoc success @ 15:03:59.358091: ac:3f:xx:xx:xx:xx: AP 192.168.xx.xx-18:64:xx:xx:xx:xx-18:64:xx:xx:xx:xx
Apr 3 15:03:59 :522295:  <DBUG> |authmgr|  Auth GSM : USER_STA event 0 for user ac:3f:xx:xx:xx:xx
Apr 3 15:03:59 :522035:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx Station UP: BSSID=18:64:xx:xx:xx:xx ESSID=COMPANY-SSID VLAN=46 AP-name=18:64:xx:xx:xx:xx
Apr 3 15:03:59 :522077:  <DBUG> |authmgr|  MAC=ac:3f:xx:xx:xx:xx ingress 0x0x100b8 (tunnel 184), u_encr 64, m_encr 64, slotport 0x0x2100 , type: local, FW mode: 0, AP IP: 0.0.0.0 mdie 0 ft_complete 0
Apr 3 15:03:59 :522264:  <DBUG> |authmgr|  "MAC:ac:3f:xx:xx:xx:xx: Allocating UUID: 0xb102176dc7acbef3
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 0 derivation_type Reset VLANs for Station up index 0.
Apr 3 15:03:59 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for ac:3f:xx:xx:xx:xx vlan 46 fwdmode 0 derivation_type Default VLAN.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 46 derivation_type Default VLAN index 1.
Apr 3 15:03:59 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for ac:3f:xx:xx:xx:xx vlan 46 fwdmode 0 derivation_type Current VLAN updated.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 46 derivation_type Current VLAN updated index 2.
Apr 3 15:03:59 :522158:  <DBUG> |authmgr|  Role Derivation for user N/A-ac:3f:xx:xx:xx:xx- N/A Set AAA profile defaults.
Apr 3 15:03:59 :522142:  <DBUG> |authmgr|  Setting default role to denyall for user ac:3f:xx:xx:xx:xx".
Apr 3 15:03:59 :522127:  <DBUG> |authmgr|  {L2} Update role from logon to denyall for IP=N/A, MAC=ac:3f:xx:xx:xx:xx.
Apr 3 15:03:59 :522049:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx,IP=N/A User role updated, existing Role=logon/none, new Role=denyall/none, reason=Set AAA profile defaults
Apr 3 15:03:59 :522246:  <DBUG> |authmgr|  Idle timeout should be driven by STM for MAC ac:3f:xx:xx:xx:xx.
Apr 3 15:03:59 :524141:  <DBUG> |authmgr|  clr_pmkcache_ft():987: MAC:ac:3f:xx:xx:xx:xx BSS:18:64:xx:xx:xx:xx
Apr 3 15:03:59 :522287:  <DBUG> |authmgr|  Auth GSM : MAC_USER publish for mac ac:3f:xx:xx:xx:xx bssid 18:64:xx:xx:xx:xx vlan 46 type 1 data-ready 0
Apr 3 15:03:59 :522254:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx rolename denyall fwdmode 0 derivation_type Initial Role Contained vp not present.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 0 derivation_type Reset Role Based VLANs index 3.
Apr 3 15:03:59 :522083:  <DBUG> |authmgr|  Skip User-Derivation, mba:0 udr_exist:0,default_role:denyall,pDefRole:0x0x10a360a4
Apr 3 15:03:59 :524124:  <DBUG> |authmgr|  dot1x_supplicant_up(): MAC:ac:3f:xx:xx:xx:xx, pmkid_present:False, pmkid:N/A
Apr 3 15:03:59 :522128:  <DBUG> |authmgr|  download-L2: acl=117/0 role=denyall, tunl=0x0x100b8, PA=0, HA=1, RO=0, VPN=0 L3MOB=0.
Apr 3 15:03:59 :522050:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx,IP=N/A User data downloaded to datapath, new Role=denyall/117, bw Contract=0/0, reason=layer 2 event driven download, idle-timeout=300
Apr 3 15:03:59 :522242:  <DBUG> |authmgr|  MAC=ac:3f:xx:xx:xx:xx Station Created Update MMS: BSSID=18:64:xx:xx:xx:xx ESSID=COMPANY-SSID VLAN=46 AP-name=18:64:xx:xx:xx:xx
Apr 3 15:03:59 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0xb102176dc7acbef3 mac ac:3f:xx:xx:xx:xx name  role denyall devtype  wired 0 authtype 0 subtype 0  encrypt-type 10 conn-port 8448 fwd-mode 0
Apr 3 15:03:59 :522038:  <INFO> |authmgr|  username=qln420 MAC=ac:3f:xx:xx:xx:xx IP=0.0.0.0 Authentication result=Authentication Successful method=802.1x server=CPPM-C
Apr 3 15:03:59 :522044:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx Station authenticate(start): method=802.1x, role=denyall///denyall, VLAN=46/46, Derivation=1/0, Value Pair=1, flags=0x8
Apr 3 15:03:59 :522158:  <DBUG> |authmgr|  Role Derivation for user N/A-ac:3f:xx:xx:xx:xx-qln420 N/A station Authenticated with auth type:  Unknown auth type.
Apr 3 15:03:59 :522142:  <DBUG> |authmgr|  Setting cached role to NULL for user ac:3f:xx:xx:xx:xx".
Apr 3 15:03:59 :522266:  <DBUG> |authmgr|  Calling derive_role2 for user ac:3f:xx:xx:xx:xx
Apr 3 15:03:59 :522016:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx IP=?? Derived role 'PRINTER' from Aruba VSA
Apr 3 15:03:59 :522127:  <DBUG> |authmgr|  {L2} Update role from denyall to PRINTER for IP=N/A, MAC=ac:3f:xx:xx:xx:xx.
Apr 3 15:03:59 :522049:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx,IP=N/A User role updated, existing Role=denyall/none, new Role=PRINTER/none, reason=station Authenticated with auth type:  802.1x
Apr 3 15:03:59 :522128:  <DBUG> |authmgr|  download-L2: acl=184/0 role=PRINTER, tunl=0x0x100b8, PA=0, HA=1, RO=0, VPN=0 L3MOB=0.
Apr 3 15:03:59 :522050:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx,IP=N/A User data downloaded to datapath, new Role=PRINTER/184, bw Contract=0/0, reason=Download driven by user role setting, idle-timeout=300
Apr 3 15:03:59 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0xb102176dc7acbef3 mac ac:3f:xx:xx:xx:xx name qln420 role PRINTER devtype  wired 0 authtype 4 subtype 0  encrypt-type 10 conn-port 8448 fwd-mode 0
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 0 derivation_type Reset Dot1x VLANs index 4.
Apr 3 15:03:59 :522254:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx rolename NULL fwdmode 0 derivation_type Dot1x Aruba VSA vp present.
Apr 3 15:03:59 :522021:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx Derived VLAN '47' from Aruba VSA
Apr 3 15:03:59 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for ac:3f:xx:xx:xx:xx vlan 47 fwdmode 0 derivation_type Dot1x Aruba VSA.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 47 derivation_type Dot1x Aruba VSA index 5.
Apr 3 15:03:59 :522253:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx derivation_type Dot1x Aruba VSA derived vlan 47.
Apr 3 15:03:59 :522254:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx rolename NULL fwdmode 0 derivation_type Dot1x MSFT Attributes vp present.
Apr 3 15:03:59 :522254:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx rolename NULL fwdmode 0 derivation_type Dot1x Server Rule vp present.
Apr 3 15:03:59 :522259:  <DBUG> |authmgr|  "VDR - Do Role Based VLAN Derivation user ac:3f:xx:xx:xx:xx role PRINTER rolehow ROLE_DERIVATION_DOT1X_VSA.
Apr 3 15:03:59 :522254:  <DBUG> |authmgr|  VDR - mac ac:3f:xx:xx:xx:xx rolename PRINTER fwdmode 0 derivation_type Dot1x Aruba VSA Role Contained vp not present.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 0 derivation_type Reset Role Based VLANs index 6.
Apr 3 15:03:59 :522161:  <DBUG> |authmgr|  Valid Dot1xct, remote:0, assigned:46, default:46, current:46,termstate:0, wired:0, dot1x enabled:1, psk:0 static:0 bssid=18:64:xx:xx:xx:xx.
Apr 3 15:03:59 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for ac:3f:xx:xx:xx:xx vlan 47 fwdmode 0 derivation_type Current VLAN updated.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 47 derivation_type Current VLAN updated index 7.
Apr 3 15:03:59 :522260:  <DBUG> |authmgr|  "VDR - Cur VLAN updated ac:3f:xx:xx:xx:xx mob 0 inform 1 remote 0 wired 0 defvlan 46 exportedvlan 0 curvlan 47.
Apr 3 15:03:59 :522257:  <DBUG> |authmgr|  "VDR - send current vlan for user ac:3f:xx:xx:xx:xx vlan 47 derivation_type Dot1x Aruba VSA trace new vlan: dot1x.
Apr 3 15:03:59 :522287:  <DBUG> |authmgr|  Auth GSM : MAC_USER publish for mac ac:3f:xx:xx:xx:xx bssid 18:64:xx:xx:xx:xx vlan 47 type 1 data-ready 0
Apr 3 15:03:59 :522095:  <DBUG> |authmgr|  ac:3f:xx:xx:xx:xx: Sending STM new vlan info: vlan 47, AP 18:64:xx:xx:xx:xx caller user_send_current_vlan_update
Apr 3 15:03:59 :522255:  <DBUG> |authmgr|  "VDR - set vlan in user for ac:3f:xx:xx:xx:xx vlan 47 fwdmode 0 derivation_type VLAN exported.
Apr 3 15:03:59 :522258:  <DBUG> |authmgr|  "VDR - Add to history of user user ac:3f:xx:xx:xx:xx vlan 47 derivation_type VLAN exported index 8.
Apr 3 15:03:59 :522029:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx Station authenticate: method=802.1x, role=PRINTER///denyall, VLAN=46/47, Derivation=9/17, Value Pair=1
Apr 3 15:03:59 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0xb102176dc7acbef3 mac ac:3f:xx:xx:xx:xx name qln420 role PRINTER devtype  wired 0 authtype 4 subtype 9  encrypt-type 10 conn-port 8448 fwd-mode 0
Apr 3 15:03:59 :522142:  <DBUG> |authmgr|  Setting cached role to PRINTER for user ac:3f:xx:xx:xx:xx".
Apr 3 15:03:59 :522053:  <DBUG> |authmgr|  PMK Cache getting updated for ac:3f:xx:xx:xx:xx, (def, cur, vhow) = (46, 47, 17) with vlan=47 vlanhow=17 essid=COMPANY-SSID role=PRINTER rhow=9
Apr 3 15:03:59 :524129:  <DBUG> |authmgr|  dot1x_gsm_set_keycache(): MAC:ac:3f:xx:xx:xx:xx GSM: Successfully published Key-cache object.
Apr 3 15:03:59 :524134:  <DBUG> |authmgr|  dot1x_gsm_set_pmkcache(): MAC:ac:3f:xx:xx:xx:xx BSS:18:64:xx:xx:xx:xx GSM: Successfully published PMK-cache object.
Apr 3 15:03:59 :524139:  <DBUG> |authmgr|  add_pmkcache():862: MAC:ac:3f:xx:xx:xx:xx BSS:18:64:xx:xx:xx:xx Update:
Apr 3 15:03:59 :522297:  <DBUG> |authmgr|  Auth GSM : MAC_USER response event for user ac:3f:xx:xx:xx:xx
Apr 3 15:08:05 :522026:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx IP=192.168.254.254 User miss: ingress=0x100b8, VLAN=47 flags=0x40
Apr 3 15:08:05 :522122:  <DBUG> |authmgr|  Reset BWM contract: IP=0.0.0.0 role=PRINTER, contract= (0/0), type=Per role.
Apr 3 15:08:05 :522125:  <DBUG> |authmgr|  Could not create/find bandwidth-contract for user, return code (-11).
Apr 3 15:08:05 :522006:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx IP=192.168.254.254 User entry added: reason=Sibtye
Apr 3 15:08:05 :522270:  <DBUG> |authmgr|  During User miss marking the user ac:3f:xx:xx:xx:xx with ingress 0x100b8, connection-type 2 as wireless, muxtunnel = no
Apr 3 15:08:05 :522318:  <DBUG> |authmgr|  Client ac:3f:xx:xx:xx:xx idle timeout 300 profile global
Apr 3 15:08:05 :527004:  <INFO> |mdns|  mdns_parse_auth_useradd_message 226 Auth User ADD: MAC:ac:3f:xx:xx:xx:xx, IP:192.168.254.254, VLAN:46, Role:PRINTER Name:qln420 APName:18:64:72:c6:f8:10 Type:1. Groups:
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_client_create 226 MDNS Client created - ip:192.168.254.254 mac:ac:3f:xx:xx:xx:xx. AP-name: 18:64:72:c6:f8:10
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_auth_userinfo_req_message 345 mac(ac:3f:xx:xx:xx:xx), ip(192.168.254.254)
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_discover_service_client 5102 Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_send_generic_refresh_query_packet 6760 record expiry: send generic refresh query for server mac: ac:3f:xx:xx:xx:xx. Num packets: 1
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  ag_send_packet_unicast 747 Pkt to SOS: pkt_len=387, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  ag_send_packet_unicast 785 MDNS Pkt len=387; src_mac=ac:3f:xx:xx:xx:xx, src_vlan=46, source_ip=192.168.xx.xxx
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_send_generic_refresh_query_packet 6777 Sending refresh request: mac ac:3f:xx:xx:xx:xx
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  ssdp_discover_service_client 666 SSDP:Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=121, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=120, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:05 :522128:  <DBUG> |authmgr|  download-L2: acl=184/0 role=PRINTER, tunl=0x0x100b8, PA=0, HA=1, RO=0, VPN=0 L3MOB=0.
Apr 3 15:08:05 :522050:  <INFO> |authmgr|  MAC=ac:3f:xx:xx:xx:xx,IP=192.168.254.254 User data downloaded to datapath, new Role=PRINTER/184, bw Contract=0/0, reason=New user IP processing, idle-timeout=300
Apr 3 15:08:05 :522301:  <DBUG> |authmgr|  Auth GSM : USER publish for uuid 0xb102176dc7acbef3 mac ac:3f:xx:xx:xx:xx name qln420 role PRINTER devtype  wired 0 authtype 4 subtype 9  encrypt-type 10 conn-port 8448 fwd-mode 0
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_parse_userinfo 376 UserInfo resp=1 ip=192.168.254.254, mac=ac:3f:xx:xx:xx:xx, apname=18:64:72:c6:f8:10, role=PRINTER, username=qln420, vlan=46
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  ag_mdns_get_token_list_for_mac 654 AirGroup user exists but token_list does not: mac=ac:3f:xx:xx:xx:xx
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  ag_ssdp_get_token_list_for_mac 360 AirGroup user exists but ssdp_token_list does not: mac=ac:3f:xx:xx:xx:xx
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_client_update 394 MDNS Client exists - flag wifi ap_name 18:64:72:c6:f8:10 client role - PRINTER
Apr 3 15:08:05 :527000:  <DBUG> |mdns|  mdns_parse_auth_userinfo_resp_message 401 UserInfo response completed for ip=192.168.254.254 mac=ac:3f:xx:xx:xx:xx
Apr 3 15:08:05 :522038:  <INFO> |authmgr|  username=qln420 MAC=ac:3f:xx:xx:xx:xx IP=192.168.254.254 Authentication result=Authentication Successful method=radius-accounting server=CPPM-C
Apr 3 15:08:10 :527000:  <DBUG> |mdns|  ssdp_discover_service_client 666 SSDP:Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:10 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=121, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:10 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=120, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:15 :527000:  <DBUG> |mdns|  ssdp_discover_service_client 666 SSDP:Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:15 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=121, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:15 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=120, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:20 :527000:  <DBUG> |mdns|  ssdp_discover_service_client 666 SSDP:Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:20 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=121, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:20 :527000:  <DBUG> |mdns|  mdns_send_packet_pseudo_mcast 511 MDNS Pkt to SOS: pkt_len=120, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:42 :527000:  <DBUG> |mdns|  mdns_discover_service_client 5102 Discover client ac:3f:xx:xx:xx:xx for a particular service
Apr 3 15:08:42 :527000:  <DBUG> |mdns|  mdns_send_generic_refresh_query_packet 6760 record expiry: send generic refresh query for server mac: ac:3f:xx:xx:xx:xx. Num packets: 1
Apr 3 15:08:42 :527000:  <DBUG> |mdns|  ag_send_packet_unicast 747 Pkt to SOS: pkt_len=387, buf_len=14336. To=ac:3f:xx:xx:xx:xx, vlan=46
Apr 3 15:08:42 :527000:  <DBUG> |mdns|  ag_send_packet_unicast 785 MDNS Pkt len=387; src_mac=ac:3f:xx:xx:xx:xx, src_vlan=46, source_ip=192.168.xx.xxx
Apr 3 15:08:42 :527000:  <DBUG> |mdns|  mdns_send_generic_refresh_query_packet 6777 Sending refresh request: mac ac:3f:xx:xx:xx:xx
MVP
So after looking at the user-debug logs it seems like everything goes fine (at least when comparing it to a laptop). The proper role and vlan are passed back from ClearPass to the controller, but the client will still not receive an IP. After a few short minutes the client takes a default IP of 192.168.254.254. It is at this point that it looks like the client is in the wrong vlan.
User-debug logs below:
