access point's Clients packets are dropped
Hi ,
I have configured aruba 215 access points and all the clients are getting packet drops when they are ping to google.com from their ipads .
we have 30 access points in the site and all are connected in a single VC
minimum 10 packets are dropped while they are pining to google.com .
please guide me to fix this issue . particularly the user whose are coonected with the SSID Mobile-WLAN only having this issues.
Re: access point's Clients packets are dropped
In the advanced portion of the SSID, make sure "broadcast filtering" is set to ARP.
what will happen if i enabled it and would i need to reboot the virtual controller after doing this?
quick reply is much appriciated
Sent from my iPhone
Performance should improve, especially in areas of high density of clients.  It does not require a reboot.
