Occasional Contributor I
active-passive master redundancy and centralised licensing
In case of using active-passive master redundancy model configured as below:
master-redundancy
  master-vrrp 1
  peer-ip-address <IP_address> ipsec <ipsec_key>
My question is if this kind of scenario I can use centralised licensing by loading licenses on active master controller? Thanks in advance.
NebojsaM
Re: active-passive master redundancy and centralised licensing
Yes.  Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/New_Licenses/Multi__Network.htm
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Colin, much appreciated.
Cheers,
NebojsaM
