I Have a Wired Static IP Active directory Network where i want to install IAP-205 Units and Add them to then same subnet as the wired network But have the WiFi Portion set as DHCP.. I Have selected a Portion of the Subnet to set asside fore the DHCP Portion But I get a Overlapping error each Time I try this ..
the Network has Servers, Printers and Workstations all between 10.0.1.2 and 10.0.1.30 with the Router (Gateway) at 10.0.1.1 I wanted to setup the Wifi Portion from 10.0.1.40 thru 10.0.1.70 .. Ive setup numerous Locations in this fashion with No Issues using Linsys & Apple Airport Extreme units But the Aruba Unit is Fighting Me..
