after upgrading the os to 6.3.1.3 my 105 AP dose not flash SSID
after upgrading the os to 6.3.1.3 my 105 AP dose not flash SSID. My controller is 3600. My 135 AP's get SSID flashed. please help me
Super Contributor I
Re: after upgrading the os to 6.3.1.3 my 105 AP dose not flash SSID
DId you see PAPI traffic to the AP105, flash the AP (Purge, sve, boot)?
Normal Guy
If you do show ap database do you see any flags on that AP ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
the ap's are in down status list
Super Contributor I
Are your APs (105 and 135) installed at different patches? If yes did you provision them the same way?
Normal Guy
Hi is there any update on this? I seem to be experiencing the same issue, we tried to upgrade to 6.3.1.3, after the controller went up our AP-105's just keeps on rebooting and won't come up. below is the logs for the "show ap image version ap-name <ap>"
AP Image Versions On
Controller
6.3.1.3(p4build@port-royal)#42233 Tue Feb 11 11:29:58 PST 2014
Access Points Image Version
AP
Running Image Version
String
Flash (Production) Image Version
String
Flash (Provisioning/Backup) Image Version String  Matches  Num
Matches  Num Mismatches  Bad Checksums  Bad Provisioning
Checksums  Image Load Status
10.27.0.242  6.0.1.3(p4build@cyprus)#28554 Tue May 31 12:37:22 PDT
2011  6.0.1.3(p4build@cyprus)#28554 Tue May 31 12:37:22 PDT
2011
No
0
1
0
0
When we rebooted the controller back to the old version (6.0.1.3) the AP's went up automatically with no issues.
My question is is there an issue with ap-105 on this version?
Thank you.
Try typing "show log system 50" to see if there are any clues about this...
thanks cjoseph. will the logs when i booted to 6.3.1.3 stay when I do show log system all? If not i will have to schedule another maintenance downtime for it? anyway i will have to upgrade to 6.3.1.5 for the SSL thing.
They will not, unfortunately.
i however remember that I managed to download the tar.logs, will post what i see later, it is with my customer.
