and/or interface 0/0 has changed: Change type is 2 ? -What does it mean?
I have just been viewing the Local events on the gui and keep seeing a reference to
User with MAC address 00:23:14:cd:9c:34 and IP address ##.##.##.##.##. from (BSSID 6c:f3:7f:3a:a6:98,AP [Name])and/or interface 0/0 has changed: Change type is 2
Can anyone indicate to me what this is?
tweet @wjhphoto
Re: and/or interface 0/0 has changed: Change type is 2 ? -What does it mean?
That is a change type trap.  The MIB guide has this:
ArubaConfigurationChangeType
Syntax Integer
create(1)
delete(2)
modify(3)
Status current
Description Configuration change types.
History Added in ArubaOS 3.1
