any way to operate 2 ap93's without controller?
Hi! I bought 2 ap-93's. I wanted to set them up and start using them, and then somebody told me that i forgot to buy the controller and that it wouldnt work without it. He was a sales representative... so im not sure if he was 100% with me. Is any way to get these ap's working without a controller? Thanks!
MVP
Re: any way to operate 2 ap93's without controller?
If they weren't IAP models, he was correct.  A controller is necessary to use the access points.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Thank you for your quick response. Somebody else told me that you could set them up using something called "mesh"?? Not sure if it exists or if it would actually allow me to set them up without a controller.
ithelpca from this forum post seems to have been able to do it.
http://community.arubanetworks.com/t5/Access-Points-and-Mesh-Routers/AP-93-mesh-and-need-to-use-different-VLANS/td-p/40562
Thanks for the help.
MVP
Those turned out to be "instant" APs or IAP
Look on the bottom (or back) of the AP.  There should be a sticker with "AP-93" or "IPA-93" or possibly "IAP-93-US"
No "I" needs a controller, with "I" is Instant and will boot up and become it's own controller.
--Matthew
Sorry for hijacking your string,
Could you tell me what is the minimum controller to purchase for say 3-4 ap93's?
No. You would have to purchase the instant version (IAP-93)
Tim Cappalli | Aruba Security
