ap-105 signal
  I have a wireless ap105 and have a clients complaining about the connectivity.    I went over and ran isSSIDer to see the signal and when I did a time graph and it looks like a persons erratic heartbeat on a ERG machine.   (in about 1 minute you see the signal strength jump from -10 to -53. (it'll do this about 30 - 40 times per minute)   The laptop is not moving nor is the access point in the ceiling (LOL)    Other places the signal strength fluctuates a bit not like this.
This isnt just one access point, its about 6 of them.
Any ideas?  HELP!
Re: ap-105 signal
What code is running on your controller?
Also, check the following command to see if the AP-105 is actually changing power levels:
show ap arm history ap-name xxxx (where xxxx is one of the APs that you are seeing fluctuate).
Do you see power/channel changes happening often?
