ap 275 mesh coverage
Hello all,
i want to add AP-275 for mesh in my existing aruba network. But i wanna ask you guys about the max coverage of AP-275 if i want doing mesh, is there any document related this? thank you for help
Re: ap 275 mesh coverage
Here's a link to the Outdoor Planner Tool which can help you make those calculations based on your environment:
https://outdoorplanner.arubanetworks.com/index.cfm?
Tim Cappalli | Aruba Security
There is nothing in there about the 275 yet (there is an update in review with techpubs). However, you are good with mesh between AP-275s out to about 400-500m, but you first really need to know what your throughput requirement is, what the interference looks like, etc to get a good idea on what you can expect. If you need to go farther in the mesh link, you need to look at the 277 or the 274 with some antenna (depending on what you need)
Jerrod Howard
many thanks for information, i will check this out soon while installation @jerrod Howard. and have a great day for you all
