Frequent Contributor I
ap277 wont provision on defined AP-Group
Hi
Am able to get an IP address for the AP, it was assigned to default group, tried to provision it to a test group but after reboot it persists in the default group.
At Configuration>wireless>AP installation.
Am i missing anything out? all we are testing for is only to broadcast a ssid.
Re: ap277 wont provision on defined AP-Group
Did you have an entry in the CAP whitelist for that AP?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
just whitelisted, able to change to the newly defined AP group but ssid not broadcasting.
