arm problem with only one channel
when I enable arm scanning ,using show ap active ,I found all ap in channel 6 in band g as picture arm1 shows.
when using show ap arm rf-suammary command ,only could found channel 6 in band g?
anyone give me some clue?
Re: arm problem with only one channel
Do you only have channel 6 in your regulatory domain profile?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks ,you are right.
