beamforming
Using a light weight Aruba 225 access point connected to a Aruba 6000 controller how to use beamforming to reduce channel interference.
Re: beamforming
Beamforming typically is not related to interference or interference avoidance.   http://en.wikipedia.org/wiki/Beamforming
What are you trying to do, specifically?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: beamforming
antenna-based beamforming I saw an post from Ruckus and thought Aruba may have a simular solution do you?
Re: beamforming
There is a great deal of technical information about this.  Please check out this long post http://community.arubanetworks.com/t5/Technology-Blog/11ac-Beamforming-Makes-the-Dog-Rollover/ba-p/163776
