Contributor II
[beginner question] Looking for clues in Airwave for why AP is down
Just noticed AP has been down for a week...
So, if you were in my shoes, and you want to take a look in Airwave for historical data for clues, where would you go?
Re: [beginner question] Looking for clues in Airwave for why AP is down
Is this a controller based AP or an IAP?
Colin Joseph
Aruba Customer Engineering
Contributor II
controller based
Airwave reports devices are down when the controller reports them as down.  So the AP for some reason stopped reporting into the controller.  There is no real way to understand why they are down until they come back up.  You should try pinging the last ip address of the AP to see if it is answering.  You should also look to see what port the AP was on and see if it is up and if the switch is giving it power.
Colin Joseph
