best Settings for 802.11g Connectivity
Mallikarjun
Super Contributor II
Re: best Settings for 802.11g Connectivity
Hi!
I think you need to be a little more specific than that if you want anyone to be able to assist you :)
Please provide some context of what you´re trying to do.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Hi Christoffer
In one of our client place they deployed ap-225 model and they are getting lattency while roaming with the 802.11b/g devices but 802.11n devices working fine.So i need to know any best practices for the driver settings, or else we need to update the drivers?
Mallikarjun
Are the 802.11n devices also connecting on 2,4 ghz or are they using 5ghz? Then perhaps your issue is a noisy 2,4ghz environment. Try verifying your radio planning with placements/shut down of some 2,4ghz radios and lowering of Tx power to minimize co-channel interference.
Also updating the client drivers is a good thing to do to see if it brings any improvements.
Cheers,
Hi ,
11n devices connecting via 5ghz.
Thank you..
Mallikarjun wrote:
Hi Christoffer
Mallikarjun
You should adjust the wifi first, before considering doing anything with the drivers.  Please PM me your email address so we can look at your tech support.
