Frequent Contributor II
br0 dropped packets
Anyone seen a problem where the br0 port is showing almost all packets dropped?
br0       Link encap:Ethernet  HWaddr 94:B4:0F:C2:B3:AC
          inet addr:10.20.31.98  Bcast:10.20.31.255  Mask:255.255.255.0
          inet6 addr: fe80::96b4:fff:fec2:b3ac/64 Scope:Link
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:357 errors:0 dropped:0 overruns:0 frame:0
          TX packets:345 errors:0 dropped:340 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
The AP is in the controller and shows as up. I can ping it with no problems. The firewalls have an allow all policy from the conrtoller to this AP. We do not see any GRE traffic coming from the conroller back to the AP.
Re: br0 dropped packets
How many and what firewalls are between your controller and AP?  Is any NAT involved?
Dropped traffic is only a symptom, it does not say everything.
A PA5050 at the main campus and a PA200 at the remote. It is a VPN IPsec tunnel with no NAT.
In the AP group, in the AP system profile, I would lower the MTU to 1100
No luck.
We have some packet captures and the GRE ID appears to only be 9000. Its listed under the "Protocol Type". Is that correct?
Moderator
hi playinpearls
gre 9000 is the heartbeat. Drop on br0 may not in itself be an issue, can you share the output of the "show ap debug system-status" for all the interfaces ? is it incrementing in real time ?
regards
-jeff
Is that the correct place to look for port 9000 in wireshark?
Here are the interfaces:
ifconfig output for eth0
eth0      Link encap:Ethernet  HWaddr 94:B4:0F:C2:B3:AC
          UP BROADCAST RUNNING SLAVE MULTICAST  MTU:9000  Metric:1
          RX packets:130053 errors:0 dropped:0 overruns:0 frame:0
          TX packets:68247 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:17449985 (16.6 MiB)  TX bytes:8594925 (8.1 MiB)
          Rx broadcast packet:0         Rx broadcast packet per second:0
          Rx multicast packet:0         Rx multicast packet per second:0
          Tx broadcast packet:0         Tx broadcast packet per second:0
          Tx multicast packet:0         Tx multicast packet per second:0
ifconfig output for eth1
eth1      Link encap:Ethernet  HWaddr 94:B4:0F:C2:B3:AC
          UP BROADCAST SLAVE MULTICAST  MTU:9000  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          Base address:0x8000
ifconfig output for bond0
bond0     Link encap:Ethernet  HWaddr 94:B4:0F:C2:B3:AC
          UP BROADCAST RUNNING MASTER MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:0
ifconfig output for br0
          RX packets:63700 errors:0 dropped:183 overruns:0 frame:0
          TX packets:63189 errors:0 dropped:63023 overruns:0 carrier:0
          Rx multicast packet:6112      Rx multicast packet per second:4
          Tx broadcast packet:17028     Tx broadcast packet per second:0
          Tx multicast packet:45646     Tx multicast packet per second:1
IP Information
Reassemble Timeout packet         0
Reassemble required packet        2
Reassemble ok packet              1
Reassemble failed packet          0
Fragments received ok packet      3
Fragments failed packet           0
Fragments created packet          10
also:
Interface Information
Inter-|   Receive                                                |  Transmit
 face |bytes    packets errs drop fifo frame compressed multicast|bytes    packets errs drop fifo colls carrier compressed reset
    lo:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
  eth0: 17448953  130049    0    0    0     0          0         0  8590221   68241    0    0    0     0       0          0          0
  eth1:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
dummy0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
 bond0: 17448953  130049    0    0    0     0          0         0  8590221   68241    0    0    0     0       0          0          0
 anul0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
   ap0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
   am0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
  gre0:       0   55383    0    0    0     0          0         0        0   64583    0    0    0     0       0          0          0
apsos0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          0
   br0:       0   63697    0  183    0     0          0         0        0   63189    0 63023    0     0       0          0          0
 wifi0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          2
 wifi1:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0          2
Is that the correct place to view the port in wireshark? (the picture)
Here is the intrerface summary from the ap:
well thats ugly.  Here's another.
          Base address:0x8000
IP Information
