can I have 2 Master controllers on same network acting as Active Masters?
  • 1.  can I have 2 Master controllers on same network acting as Active Masters?
    Posted Sep 29, 2016 03:05 AM
    Can I have 2 Master controllers in same network to be in Active active using VRRP?
  • 2.  RE: can I have 2 Master controllers on same network acting as Active Masters?
    Posted Sep 29, 2016 04:02 AM
    Hi!
    If you want to have them syncing configuration and databases to eachother directly then no, the master-redundancy is active-passive. I´d recommend using master-redundancy or a master-local setup.
    On the other hand there´s a deployment option called "all master" where you have standalone masters instead of locals in your system. To syncronize configuration in between them you can use Airwave as management.
    Cheers,
