can a same vlan use both voice and data traffic?
what kind of devices are needed to use both voip and data?
Aruba
Re: can a same vlan use both voice and data traffic?
With Aruba's solution you can re-use the same VLAN for voice and data traffic.
These days, with SmartDevices the defacto standard, it's all but guarantee'ed that devices will have multiple traffic types.
Use Aruba's PEFNG, Device, and Application awareness to fine tune your network's performance rather than the traditional voice vs. data VLAN construct.
JF
See our VRD page for very indepth and proven deployment configurations.
http://www.arubanetworks.com/technology/reference-design-guides/
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
