can aruba 200 running v3.3 be slave to aruba 800 v5.0.4
Can aruba 200 be upgraded to introduce as slave to aruba 800 v5.0.4
Re: can aruba 200 running v3.3 be slave to aruba 800 v5.0.4
Yes.
Hi Joseph,
This is to say I need to upgrade aruba 200 to v5.0 before I can upgrade.
Correct.
