can i create a gre tunnel between two contollers?
He have setup tunnel between two controllers,, but the tunnel is not coming up. The controllers indicate the tunnel is up, but can't png the local or remote tunnel interfaces. Is there some examples of how to this other than the Aruba OS Guide? Using 6.1.3.0
Valued Contributor I
Re: can i create a gre tunnel between two contollers?
Layer 2 or Layer 3 tunnel?
Kudos appreciated, but I'm not hunting! (ACMX 104)
Sorry, the link doesn't work ....
Try here:  http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Using-GRE-Tunnels-to-centralize-L3-access/m-p/2831
