can not use AP 303 as virtual controller
  • 1.  can not use AP 303 as virtual controller
    Posted Mar 29, 2018 10:42 AM
    My customer have AP303 x 22 APs at office now. But i can not config it to be virtual controller
    It use unify ap on ap after connect to ap if select
    - virtual controller it have 2 option
    1.load firmware from local file
    2.load firmware from url
    I can not find firmware 8.3.x.x for AP 303 coz firmware come with AP 303 is 8.3.0.0
    Anyone can config AP303 please give me step to config it.
    Many thanks and best regards,
    Anucha Kositkulchon
  • 2.  RE: can not use AP 303 as virtual controller
    Posted Mar 29, 2018 07:58 PM
    The software needed for AP-303 (both AOS and Instant, 8.3.0.0) is still in beta stage, and has not been released.
    You can download the beta image from the Aruba support portal, and upgrade the image on the AP (Instant) or controller (AOS).
    The AP units themselves ship with a basic/incomplete version of the 8.3.0.0 code, which cannot be used to run the AP in operational mode.
  • 3.  RE: can not use AP 303 as virtual controller
    Posted Apr 06, 2018 11:47 PM
    I got 8.3.0.0 beta code from support. 8.3.0.0 not have on download site.
    after upload to AP303 it can work as Virtual controller fine.
    many thanks for support team.
  • 4.  RE: can not use AP 303 as virtual controller
    Posted Jun 07, 2018 08:03 AM
    Dear ALL,
    have you solved the issue ? i have the similar scenario with AP-303 (RW) access points software version 8.3.0.0 not working   and converting to virtual controller or standalone access points ,
    whrere the 8.3 release has been dragged from aruba support center .
    plz advice , how can use it as standalone AP
  • 5.  RE: can not use AP 303 as virtual controller
    Posted Jun 07, 2018 08:07 AM
    Dear prince ,
     please if you can provide me with 8.3 beta version
     thank you .
  • 6.  RE: can not use AP 303 as virtual controller
    Posted Jun 07, 2018 09:16 AM
    The IAP 8.3.0.0 software for the IAP-303 is available here:
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=29671
    You may need a valid support contract in order to download from that link.
    I'm not sure what you mean about the software being dragged from the support site. It's still there, for both IAP and controller based.
  • 7.  RE: can not use AP 303 as virtual controller
    Posted Jun 08, 2018 08:31 AM
    Worked fine the 8.3 beta version
    thank you .
  • 8.  RE: can not use AP 303 as virtual controller
    Posted Oct 22, 2018 05:32 AM
    How to create  AP’s master controller. device in AP 303-RW .
    Or where can I find help for its creation or video
  • 9.  RE: can not use AP 303 as virtual controller
    Posted Oct 28, 2018 10:51 PM
    When you power on the AP-303, if a virtual controller or Mobility Controller is not detected, the AP will automatically become (create) a virtual controller for itself.
