can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
can you help on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI,if possible with screenshots.Thanks in advance,.
Valued Contributor II
Re: can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
Hi Karthik,
Which RAP model you are using ?
Cheers,
Venu Puduchery,
The method is same for any AP. To insist you RAP to use only a-band we need to disable g-radio(in case if the RAP is dual band) as shown in the snapshot and select RF band as "a" in the AP system profile.
for your ref :
Please feel free for any further help needed.
Cheers,
Venu Puduchery,
