Contributor I
captive portal authentication timeout
Hi everyone. I'm using captive portal authentication of my wireless clients. ArubaOS version is 6.3.1.13. So, can anyone tell me about client sessions timeout in captive portal authentication. Where can I find and modify this parameter? Is there any default session time or idle timeout for guests?
Re: captive portal authentication timeout
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-user-idle-timeout-for-different-profiles-in-an/ta-p/239008
Sent from Outlook for iPhone
Thank you
Victor Fabian
Lead Mobility Architect @WEI
In the Captive Portal authentication profile, there is a user idle timeout which will allow you to change the default from 5 minutes.
