Hi.
I going to set up captive portal with 3400 controllers and I've got couple of questions.
Does captive portal require connectivity with DNS server before authentication?
Does controller need IP address for guest subnet and does controller have to be a gateway or I can use other device as gateway for guest subnet?
Is it possible to configure DHCP relay on controller for guest subnet?
Thanks for help,
#3400
