Hi
We are using controller 3600 and rap2wg in the remote site...we have configured split tunnel for the ssid so that guest users can have captive portal authentication.
With regards to the above setup please clarify the below queries
1. Do we need to create a vlan and dhcp on the controller for the users to fall into?
2. If we have to create a dhcp for the vlan what should be the gateway? If we assign the private IP address from the dhcp will the user be able to reach the internet via DSL ?
#3600
