Contributor II
captive portal role derivation and vlan assignment
Hi all.
I am trying to configure guest network with open ssid and using internal captive portal. authentication is done in clear pass and authenticated role is pushed to controller from clearpass.
Before authentication role is logon and 1001 is the vlan assignment to the role. I am getting the IP addres from 1001.
After authentication role is guest and 203 is vlan assignment to the role but i am unable to get the ip address  and doesnt change from 1001.
Is it possible to change vlans when we are doing with L3 authentication??
Re: captive portal role derivation and vlan assignment
Not possible with Captive Portal, because the physical devices does not know that the layer 2 network has changed in the background.  There is a way, where you can give a DHCP lease on the initial VLAN of 30 seconds or less and the client will re-dhcp and get an ip address on the new VLAN, but it is not practical.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
I am able to get the new role .
Actually i have tried to release and renew the ip address but still it didnt changed.
This is after the client has authenticated via captive portal?  Are you sure that you are allowing DHCP traffic in the post-authentication role?
Contributor II
For post authentication role, i have allowed all
Does DHCP work on the new VLAN?  Does "show user-table verbose" show that the user has been switched to the new VLAN?
Contributor II
yes dhcp on controller is configured.
and i have checked user-table verbose. I can see role assigned but vlan is not changing.
What are you using to change the vlan?
Changing vlan by specifying in the new role doesn't work for L3 authentication like captive portal.
In the CLI guide for command 'user-role <role> vlan x'
Identifies the VLAN ID or VLAN name to which the user role is
mapped. This parameters works only when using Layer-2
authentication such as 802.1X or MAC address, ESSID, or
encryption type role mapping because these authentications
occur before an IP address is assigned. If a user authenticates
using a Layer-3 mechanism such as VPN or captive portal this
parameter has no effect.
 You could probably switch the vlan by having a server derivation rule based on an attribute returned by Clearpass, but I've not tested exactly that for captive portal.  You would still need the short initial lease as Colin mentioned though.
ACCP, ACCX #817, ACMP, ACMX #294
Contributor II
Role derivation from clear pass. and i have assigned post authenticattion vlan to that role in controller
