I want to ceiling mount AP 274(antenna used are ANT-3x3-2005 & ANT-3x3-5005), which mounting kit should i use?
Thanks.
The 274 should have a kit to ceiling mount it. Do you mean you want to ceiling-mount the antennas?
hi colin, thanks for your reply
i want to mount ap 274 to ceiling, can you please help me with the correct part code number. can i use AP-270-MNT-H1 .
Another query which I had was that in 274, will the antennas be mounted at the bottom of the AP?
mohan007,
I apologize, I thought you were talking about the 224 when I answered. The ceiling mount kit is not included and like you mentioned it should be the AP-270-MNT-H1. You are correct.
The question is why would you not just ceiling mount the AP-275, instead of getting external antennas? What kind of area are you trying to cover?
