Frequent Contributor II
centralised licensing issue
Hi all, have 2 x controllers in master/slave config, using vrrp for failover.
All ap's configured as raps pointing to vip (master).  Upgraded controllers to 6.4,enabled centralised licensing.When master is taken down local doesnt inherit license count... ??
Any ideas ??
ACMA/ACMP
Re: centralised licensing issue
You might didnt configure your controllers as needed:
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-and-verify-centralized-licensing-in-a-master/ta-p/187208
Is it configured as a local or a standby master ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Did you do a write memory?  The contralised licensing commands are something that get pushed down to locals.
ACCP, ACCX #817, ACMP, ACMX #294
Its master/local, according to TAC its configured corectly, but if the master fails the licenses act rather like a dhcp lease, and will be available on the local (30 days) but still cant make out if they show via the cli ??
ACMA/ACMP
Can you run the show switches from the master to make sure you can see the local
And also run the show license client-table
Thank you
Victor Fabian
