change to MSR2000 and MSR4000 WDS / AP80MB/SB discontinued product
Hi
Our customer using AP80MB/SB  and Aruba discontinued this product (end Of line ) we will  offer a solution  our customer .with MSR2000/4000.
We have  two AP80MB backhaul Master/Slave  and in the field  we have  eight     AP80SB/Access Point .MSR2000 and MSR4000  how many multipoint
WDS connection supporting on MSR2000/4000. .Can we change this topolgy AP80MB/SB to MSR2000 and  MSR40000.
Aruba
Re: change to MSR2000 and MSR4000 WDS / AP80MB/SB discontinued product
Hi Fantasio,
The AP80 series is a single radio unit.  So depending on the geometry of the network you may be able to replace with our MST200 which is also single radio.  MST200 has an integrated high gain antenna as well.
Can you explain what antennas you are using, and provide a layout of the network so I can give you more specific feedback?
-cl
