changing regulatory domain on aruba 3600 controller
  Hi ,i am using Aruba 3600 controller curently operating in GB regulatory domain.I want to change the regulatory domain of my controller.Can some one tell me how to do so and is there a reboot required for the change to take effect.
Re: changing regulatory domain on aruba 3600 controller
You would need to run the startup Wizard again.
Thanks for the answer,If i change the regulatory domain of APs in a specific group using AP profiles.In that case would i be needing to reboot controller for the changes to take effect.
If you just change it on the regulatory domain profile, it does not require a controller reboot.  My answer is if you wanted to change the regulatory domain of an entire controler.
Thanks ,really appricate the prompt response.
