cli command for provision-ap
Hi everyone,
I know in aruba CLI there is command for provision-ap and re-group.  So my question is if I have ap name "ap-1" is already provisioned but I want to change its ap-group and at the same time makes it as "mesh portal" in mesh role.
can I do this?
ap-name ap-1
ap-group apgroup-A
mesh-role mesh-portal
ap-name ap-2
ap-group apgroup-A
Any suggestion is great appericate!
Re: cli command for provision-ap
Provision one firstly as normal via the gui, then in the cli do a "show audit" to see what the necessary commands are.
ACCP, ACCX #817, ACMP, ACMX #294
