cli commands to troubleshoot wifi coverage
  • 1.  cli commands to troubleshoot wifi coverage
    Posted Dec 10, 2014 06:37 AM
    I am looking for some help with troubleshooting commands for assessment and troubleshooting of wireless coverage. How to find if the coverage is poor in some areas and signal strength is poor and if there is congestion? A link where some of these troubleshooting commands and the output meaning is available will also be helpful.
  • 2.  RE: cli commands to troubleshoot wifi coverage
    Posted Dec 10, 2014 06:44 AM
    falam,
    The best thing you can use to test wireless coverage, is the device that uses wifi.  Why?  Because access points can only tell coverage from their perspective.  Wifi coverage is best determined by devices that need wifi.  If it is a Windows or Mac OSX laptop, try inssider:  http://www.inssider.com/  If it is an android device, Aruba Utilities is your best option:  https://play.google.com/store/apps/details?id=com.arubanetworks.arubautilities
    -65 and stronger is generally a good number.
    To see how well other access points see each other, you can use the command "show ap arm state <name of access point>"
