Contributor I
client not connecting to nearest ap
We have aruba ap installed for almost a year however there is an issue that keep bothering me that is the clients are not connecting to the nearest ap instead it is connecting to the ap a floor above or below. Our building is full of concrete wall and signal is hard to travel from one room to another.  As a result, when the client is connect to the ap above, the signal is not good and will affect the transfer rate. i did a ping test with the client machine connecting to ap at one floor above there is a lot of connection drop. i had disable channel load balancing, but it is not helping. Appreciate for any useful advice
Re: client not connecting to nearest ap
Please try the solution in the thread here:  http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/quot-Sticky-Client-quot-Problems/m-p/9123/highlight/true#M3478
Are these clients running Windows? I have seen this issue with older wifi drivers on Windows computers. Please ensure that the drivers are up to date.
Zach Jennings
Contributor I
no. they are all mac client. all the driver is up to date. However, i heard from someone telling me that mac is not good in wireless. :(
Ok. Please try the steps in the thread that Colin posted, and let us know how it goes.
Zach Jennings
Contributor I
i had remove the 802.11g transmit rate of 1, 2, 5 and will monitor the status.
Sounds like you've got sticky clients.
If removing those transmit rates doesn't work it might be worth trying Station Handoff Assist.
Allows the controller to force a client off an AP when the RSSI drops below a defined minimum threshold.
Default: Disabled
James.
Cheers
James
Default: Disabled
James.
There are a few clients out there that will not associate if they do not see the lower rates, so removing them is no longer a preferred method.  Using station handoff is also no longer a preferred method, because it sends deauths to a client when it is at a certain signal level and some clients consider this disruptive.
Please use the local-probe-response-threshold method, since that is the more modern, standards-based and least disruptive method to clients.
Ah well it looks like abcstop has got the wrong end of the stick with the link you posted and has disabled the lower data rates.
Thanks for the info on the station handoff assist!
I see that this is the bit you were referring to in the linked post:
As of ArubaOS 5.0.3 and 3.4.3 and above, there is a parameter in the SSID profile called local-probe-req-thresh which will ignore probes from clients that are below a certain threshold
(Aruba3200) (SSID Profile "test") #local-probe-req-thresh ?
requests will get ignored (only used if
local-probe-response is also enabled)
You should try it with an SNR of 20
Cheers
James
jrwhitehead,
I can see how abcstop got the wrong idea.  Thanks for that clarification.
