collaborative application not running
I havec collaborative application which comes with a device like multipad. It is connected to a wlan and the others are also connected to the same wlan .
its a common place to share the videos ,IM ,broadcast videos . unfortuantely clients cannot connect to the multipad
Please help
Re: collaborative application not running
Is this a controller-based system or instant?
Are you using encryption?
Do you have broadcast filtering enabled?
What protocol does the application use?
