compression of Aps 175 and 275
Hi All
Please some one guide me whene can i find the compression between aruba AP 175 And 275
Re: compression of Aps 175 and 275
Please elaborate....
If you mean comparison, the 175 is an 11n 2x2 outdoor AP with four N connectors (2x2.4Ghz and 2x5Ghz). The AP-275 is an 11ac 3x3 with integrated omni-directional antennas. The datasheets for both are out on the web.
Jerrod Howard
What do you mean by compression?
Sent from Nine<>
Tim Cappalli | Aruba Security
Contributor II
I'm sure they meant "comparison" and not "compression".
