Regular Contributor I
configuring controller for terminating l2tp ipsec session.
how can i configure controller to terminate l2tp ipsec session. Please advise.
Thank you.
Aruba
Re: configuring controller for terminating l2tp ipsec session.
I would start with the user guide.  There is a chapter on VPNs that outlines the setup.   See the following HTML of the user guide to get you started.
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/VPNs/Configuring_a_Basic_VPN_.htm
AMFX | ACCX | ACDX | ACMX
Thank you Clembo, i made it working in the lab.
