connection tow building with mesh RAP
can i connect tow building with RAP and both of them are Mesh portal or one of them should be mesh point
Regular Contributor I
Re: connection tow building with mesh RAP
Hi
One should be remote mesh portal, and one mesh point.
Are you talking about a RAP AP like RAP-109, or RAP function?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
