connectivity issues
I am currently testing 1 AP-105. This is connected to a port on my firewall, where I have set everything open, but sometimes I have some problems. The problem seems to be that most sites users go to will be hit or miss on of they will load, or when they will load. For example when trying to go to www.cnn.com might not work, but checking after 5 minutes it will. Then it might only load the very basic html copy of the site, with everything striped out, until you refresh and eventually get the full version of the site. Local content, such as file shares and even Spiceworks provide no issues for the wireless connections. It only seems to be content and data coming from the internet. Also, e-mail connections and logmein connections will be connected with no issues even if you're unable to get to another site that is, in fact, up.
Here is a copy of my log file:
 12/16/2013 19:57:43 PM    Target: AP_Receptie    Command: show log debug
Dec 16 19:55:28  awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response: HTTP/1.1 302 ^M Server: ^M Date: Mon, 16 Dec 2013 18:54:28 GMT^M Cache-Control: no-cache,no-store,must-revalidate,post-check=0,pre-check=0^M Location: https://10.0.14.10:4343/swarm^M Content-Type: text/html; charset=utf-8^M Content-Type: text/html; charset=utf-8^M Connection: close^M ^M <HTML> <HEAD><TITLE>302 </TITLE></HEAD> <BODY BGCOLOR="#cc9999" TEXT="#000000" LINK="#2020ff" VLINK="#4040cc"
> <H4>302 </H4>  <ADDRESS><A HREF="http://www.arubanetworks.com"></A></ADDRESS> </BODY> </HTML>
Dec 16 19:55:28  syslogd: Syslogd error: Unable to parse find msg id 0
Dec 16 19:55:28  awc[1009]: Sent header(len=274) 'POST /swarm HTTP/1.1^M Host: 10.0.14.10^M Content-Length: 0^M X-Type: login^M X-Guid: 302035870170deb51978ae8edc435ea4ea2a2192bdcc978528^M X-Name: Instant-CD:FA:07^M X-Organization: ^M X-Shared-Secret: WIfi6622^M X-OEM-Tag: Aruba^M X-Ap-Info: BT0750379, 24:de:c6:cd:fa:07, AP-105^M ^M '
Dec 16 19:55:28  awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response: (null)
Dec 16 19:55:41  mini_httpd[12916]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:55:41  awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:00  mdns[1041]: trace_rotate_file: rotating /var/log/trace/mdns.log
Dec 16 19:56:00  mdns[1041]: trace_on: tracing to "/var/log/trace/mdns.log" started
Dec 16 19:56:00  awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:11  mini_httpd[12933]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:56:11  awc[1009]: Message over SSL from 10.0.14.10, SSL_read() returned 0, Message is "", AWC response:
Dec 16 19:56:41  mini_httpd[12953]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:56:46  mini_httpd[12952]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:11  mini_httpd[12970]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:14  mini_httpd[12971]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:14  syslog: User admin IP 10.0.14.49 login by web UI successfully
Dec 16 19:57:15  mini_httpd[12982]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15  mini_httpd[12983]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15  mini_httpd[12987]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15  mini_httpd[12988]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:15  mini_httpd[12986]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16  mini_httpd[12991]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16  mini_httpd[12994]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16  mini_httpd[12993]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16  mini_httpd[12992]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:16  mini_httpd[12995]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:17  mini_httpd[12991]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:17  mini_httpd[12994]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:18  mini_httpd[12986]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:18  mini_httpd[13002]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:19  awc[1009]: Writing on SSL connection failed even after 25 tries, Error code: 5
Dec 16 19:57:19  awc[1009]: disconnected from airwave 10.0.14.10
Dec 16 19:57:19  cli[1026]: <341004> <WARN> |AP AP_Receptie@10.0.14.10 cli|  awc_logout
Dec 16 19:57:19  awc[1009]: [truncated] awc_login: 1621: writing device_cert_pem='-----BEGIN CERTIFICATE----- MIIG4zCCBcugAwIBAgIKfBqYrQAAAE6QszANBgkqhkiG9w0BAQUFADBdMRMwEQYK CZImiZPyLGQBGRYDY29tMR0wGwYKCZImiZPyLGQBGRYNYXJ1YmFuZXR3b3JrczES MBAGCgmSJomT8ixkARkWAmNhMRMwEQYDVQQDEwpERVZJQ0UtQ0ExMB4XDTEzMDgy MjAyMTc0NloXDTMyMDkxNDAzMjExNFowJzElMCMGA1UEAxMcQlQwNzUwMzc5Ojoy NDpkZTpjNjpjZDpmYTowNzCCASEwDQYJKoZIhvcNAQEBBQADggEOADCCAQkCggEA tuy2hfo7ZXiF0u7IuQytrHaX9V9OXGSWOejx7g5OsmOF/n12HSW6AEtMIStFTPtI hECM4Bg/4gh
A3RbRC0d1CI82jM9/iGC9G3/Kyek8/Xf0vO6SY6zHpMeFH8YX80ZE HHhPRrT86gBRRc0/OM0Xtj8DkcO5KBoKZYFV59wegE/fB8/dncCIhdRzflCQEnOZ /OkdBHus00tsKjGdE/NWS/nFRV3mcF3uEMPpsuQSSSD8E1tvi02dAA0/cf7sBz4o P6+HygCe4Y3YSM3oihJSkxtdei7HIP0XiL8jXbDRMACgVLPBx+5swi+mFxyamg+I N5pbOSUOPKvbmsBsi46RiQIDAQABo4ID2jCCA9YwPQYJKwYBBAGCNxUHBDAwLgYm KwYBBAGCNxUIg72/SIbntyuG1YMwqq9JhbDpfIFQgpjWR4fLpwoCAWQCAQMwJwYD VR0lBCAwHgYIKwYBBQUHAwQGCCsGAQUFBwMTBggrBgEFBQcDAjAOBgNVHQ8BAf8E BAMCBsAwMwYJKwYBBAGCNxUKBCYwJDAKBggrBgEFBQcDBDAKBggrBgEFBQcDEzA
Dec 16 19:57:20  mini_httpd[13003]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:20  mini_httpd[12987]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:20  mini_httpd[12988]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:20  mini_httpd[13005]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:20  mini_httpd[13006]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:21  mini_httpd[12993]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21  mini_httpd[12992]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21  mini_httpd[12995]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:21  mini_httpd[13002]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:22  mini_httpd[13009]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:23  mini_httpd[13012]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:23  mini_httpd[13013]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:23  mini_httpd[13015]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:23  mini_httpd[13014]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:25  mini_httpd[13003]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25  mini_httpd[13004]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25  mini_httpd[13005]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:25  mini_httpd[13006]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:27  mini_httpd[13009]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:28  mini_httpd[13013]: handle_read_timeout: 4226: child exit after 1 requests
Dec 16 19:57:29  awc[1009]: awc_connect to 10.0.14.10
Dec 16 19:57:29  mini_httpd[13022]: handle_request: 1760: SSL_accept fail, child exit after 0 requests error:00000005:lib(0):func(0):reason(5)
Dec 16 19:57:30  mini_httpd[13024]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:30  syslog: process_msg_ref: 20: got msg_ref of len 10453 and body '/tmp/.cli_msg_zSL1rO'
Dec 16 19:57:30  syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_zSL1rO'
Dec 16 19:57:30  syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:30  syslog: process_msg_ref: 41: read large msg of 10452 bytes
Dec 16 19:57:35  mini_httpd[13023]: handle_request: 1794: got nothing, child exit after 0 requests
Dec 16 19:57:39  mini_httpd[13030]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:39  syslog: process_msg_ref: 20: got msg_ref of len 11017 and body '/tmp/.cli_msg_T3cOyK'
Dec 16 19:57:39  syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_T3cOyK'
Dec 16 19:57:39  syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:39  syslog: process_msg_ref: 41: read large msg of 11016 bytes
Dec 16 19:57:40  mini_httpd[13029]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Dec 16 19:57:40  syslog: process_msg_ref: 20: got msg_ref of len 11482 and body '/tmp/.cli_msg_Ui0Zkb'
Dec 16 19:57:40  syslog: process_msg_ref: 33: opening '/tmp/.cli_msg_Ui0Zkb'
Dec 16 19:57:40  syslog: process_msg_ref: 38: reading large msg
Dec 16 19:57:40  syslog: process_msg_ref: 41: read large msg of 11481 bytes
Dec 16 19:57:43  mini_httpd[13037]: tp_acl_cp_user_get: 1489: Could not retrieve valid data from datapath for session '10.0.14.49'-'10.0.14.48'
Re: connectivity issues
And I have these issues only when I connect witch the Aruba AP. I have some basic AP's and these work fine...
Aruba
Try to change the MTU setting in the ap-system profile to 1400.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Is that under Services - Calea and then change MTU to 1400?
Aruba
it sounds like you have an Instant AP.  I'm not sure where to change the MTU on those.  It might be listed in the UG or CLI guide, or someone else may be able to suggest
Aruba
Can you paste your config as well as the switchport config on the wired uplink?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
The AP is connected to a port on my Fortigate 100D firewall. On this port the following is applied:
- ip/netmast: 10.0.14.254/255.255.255.0
- My windows server is DHCP-server and DNS Server
- All access from that port to server and wan is allowed now
This is my current configuration in the AP:
version 6.2.1.0-3.4.0 virtual-controller-country BE
virtual-controller-key 302035870170deb51978ae8edc435ea4ea2a2192bdcc978528 name WIFI_Houtland organization houtland.be
virtual-controller-ip 10.0.14.5
ntp-server 0.be.pool.ntp.org clock
timezone Amsterdam 01 00 rf-band
all ams-ip 10.0.14.10
ams-key deleted
allow-new-aps allowed-ap
24:de:c6:cd:fa:07
arm wide-bands 5ghz
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system s
yslog-level warn user
syslog-level warn
user-debug
syslog-level
warn wireless
mgmt-user admin
wlan access-rule
default_wired_port_profile index 0
rule any any match any any any permit
wlan access-rule CVO_Administratie index 5
CVO_Administratie enable index 3
type employee
essid CVO_Administratie
wpa-passphrase
opmode wpa2-psk-aes
max-authentication-failures 0
auth-server InternalServer rf-band all
captive-portal disable d
tim-period 1
inactivity-timeout 1000
broadcast-filter none
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
auth-survivability cache-time-out 24
wlan external-captive-portal server localhost port 80 url "/" auth-text "Authenticated" blacklist-time 3600 auth-failure-blacklist-time 3600 ids wireless-containment none wired-port-profile
switchport-mode trunk allowed-vlan all native-vlan 1 shutdown access-rule-name default_wired_port_profile speed auto duplex full no poe type employee captive-portal disable no dot1x wired-port-profile wired-instant switchport-mode access allowed-vlan all native-vlan guest no shutdown access-rule-name wired-instant speed auto duplex auto no poe type guest captive-portal disable no dot1x enet0-port-profile default_wired_port_profile uplink preemption enforce none failover-internet-pkt-lost-cnt 10 failover-internet-pkt-send-freq 30 failover-vpn-timeout 180 airgroup disable airgroupservice airplay disable description AirPlay airgroupservice airprint disable description AirPrint
