Contributor II
controller Reboot Cause: Power Cycle
Dear All,my controller 7205 usually reboot recently, the last one reason is power cycle. what causes it ? what is power cycle in Aruba controller ? I use command " show version " and found error, who can help me how to fix it, very tks.
(Aruba-7205-IACJ-Master) #show version
ArubaOS (MODEL: Aruba7205), Version 6.4.3.2
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-06-03 at 16:33:32 PDT (build 50323) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.1.0 (build 48228)
Built: 2015-01-22 04:53:25
Built by: p4build@re_client_48228
Switch uptime is 1 days 10 hours 10 minutes 39 seconds
Reboot Cause: Power Cycle (Intent:cause:register ee:ee:0:c)
Supervisor Card
Processor (XLP316 Rev B2 (Secure Boot) , 1200 MHz) with 7882M bytes of memory.
32K bytes of non-volatile configuration memory.
3872M bytes of Supervisor Card system flash.
Re: controller Reboot Cause: Power Cycle
Please open a TAC case so that they can look at your issue in depth.  We cannot tell what the issue is in that show version output.
