Occasional Contributor I
controller clustering with remote ap's
hi,
we tried to cluster the controllers but afterwards all remote ap's went down.
I cannot see how clustering for RAP's should work because they connect through NAT to the controller vrrp ip and cannot reach the individual controllers.
Why is this not working? and can't i disable clustering for RAP's?
Frequent Contributor I
Re: controller clustering with remote ap's
are you working with version 8.x software or version 6.x ?
ACCP ACMP CWDP CWSP
If you using AOS8 clustering NAT is not supported with this design , you will need to assign direct public address to each controller
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
yes, 8.1.2 with mobility master.
And no, we are not going to put a public ip on the controller.
I wasn’t suggesting you do but that’s the only way you can support RAPs while using clustering.
Otherwise you will need to have separate controllers (not part of a cluster) for your RAPs or use the existing controllers with no clustering
Thank you
Victor Fabian
Thank you
Victor Fabian
As mentioned above, it's a known/stated limitation with AOS8.x. This is due to how controller information is signaled to APs when clustering is enabled, via the nodelist, which takes priority over the previous controller discovery options.
The previous methods of RAP redundancy using LMS and Backup LMS IPs in combination with VRRP are still options, but due require that the controller not be a part of a cluster.
Charlie Clemmer
Aruba Customer Engineering
will this be fixed in a future version?
This means in order to use this we have to buy 2 extra controllers.
Please register your request here:  https://innovate.arubanetworks.com/ so that HPE will see demand for that feature.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
looks like you need to sign in as a partner or hpe employee.
no customer. nice... :(
Internally the issue has been raised and is being discussed.  I will point them back to this thread.  No need to post.
