controller with ospf and 3G always up running ospf
Hello.
For a customer that needs a single device to do routing ospf over ethernet and umts can we use the controllers ?
We need 3G to be up running ospf 24/7 on are backbone. In the future it will be another area so it has to be able to be border router ospf.
Is this doable ? With what limitations ?
Thanks, regards
Alex
Alcatel-Lucent Enterprise Italy
Re: controller with ospf and 3G always up running ospf
Assume you want to setup controller to use enet as primary link and run ospf over that. then you want to use 3G as a backup with static default route in case enet is down. then yes this is doable as long as your ospf route is more specific. if the controller relies on the default route receivd from ospf neighbor then unfortunately this will not work because the static default route is more prefered than the ospf default...
ABR function is supported on AOS6.x or newer.
HTH.
