copy controller configuration
We have a 3400 series controller, and we want to upgrade to 3600 . If there a way to copy all the configuration from 3400 to 3600 including network configuration(VRRP,vlans ect) .
Re: copy controller configuration
you can backup the flash from the old controller and restore them on the new controller.
The Below KB article should help you
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-234
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
Dear Vinod,
Thanks for your response and suggestion . Will the flash contain license information . If i copy flash from 3400 to 3600 will it copy licenses too .
MVP
In terms of licenses - take a look at this thread:
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/moving-licenses/m-p/38466
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Occasional Contributor I
you need to copy the licenses to the flash first. find the export/import license under controller configuration -> licenses
though, i think the licenses is bound by the SN of the controller.
Thanks, will this work if we want to copy the exact configuration from 3400 to 3600 controllers ?
well, i never tried it but i think yes with a little adjustment in ports and ip configuration.
make sure you try it first before fully implement it.
If you are paranoid (like me), you might want to do a "show ap active" and grab a list of the connected APs.
http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/showap.htm
If on the same L2 network, they should all come back on okay.  But if there are problems (different L2 etc), then you at least have a quick cheat sheet of which APs might be looking for a home.
