delete and edit OLD SSID
when i delete old SSID and save configureation it apear again can you giude me why is this and how can i delete old SSID from my aruba controller 7210 latest version
Re: delete and edit OLD SSID
Are you completeing the wizard? The commands to remove the SSID are not pushed until the end of the wizard.
Also have you tried deleting the SSID profile via the CLI?
