deploying M3 card in oaw 6000 chassis
Please clarify me on the below queries
1. Is it possible to insert M3 card in all the four slot of 6000 chassis ?
2. If it is possible then can we have different software version in each card ?
Thank you
Re: deploying M3 card in oaw 6000 chassis
Yes to both questions
Thank you
Victor Fabian
Lead Mobility Architect
