Frequent Contributor I
devices supported for mobility master
May i better understand for devices supported are we referring to controllers and AP only for mobility master?
Frequent Contributor II
Re: devices supported for mobility master
Yeah thats correct. Each AP and controller being managed by MM will be considered as a devcie and will occupy one license.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
