dhcp boardcast question
is there a way for the dhcp boardcast message change to dhcp unicast message to dhcp server on controller?...my controller model is 7xxx....
the dhcp request is from the clients...
i remember there is a way, but cannot find out again...any one knows? please help..
Re: dhcp boardcast question
Are you trying to setup a DHCP relay? You can add one under the IP interface.
Tim Cappalli | Aruba Security
is there a way (expect the dhcp relay) to turn the boardcast dhcp request to unicast ?
The relay always unicasts the DHCP request to the DHCP server, if that is what you mean.  If the client and the DHCP server is on the same subnet it is a broadcast and a relay is not used...http://en.wikipedia.org/wiki/DHCP_Relay_agent
Colin Joseph
Aruba Customer Engineering
