dhcp snooping and DAI in wireless
i was just set up a wireless network for a school use aruba 7xxx series. the deploy model is master/local. the clients get ip from external  dhcp server .
now, i meet a problem is,here someone is pretend a dhcp server in the network, i think it is a dhcp attack. is there any setting need to enable on controller to avoid this case happen?
many thanks everyone give me some advices
Re: dhcp snooping and DAI in wireless
If you are using the "logon-control" ACL in your user roles, there is an entry that blocks clients from serving DHCP addresses.
Tim Cappalli | Aruba Security
very appreciated...very helpful idea...but is there a way for mitigate man in middle attack? i mean that if some one pretend the gateway ip address, he will ruin the whole network...any setting on the controller ?
There are two things you can do:
1) Enable "Enforce DHCP" in your AAA profile. This will stop a user from entering the user table if they did not receive their address via DHCP
2) Add your gateway addresses to the validuser ACL.
ok...i try it later...thank you very much
